Results 1 to 10 of 16
Thread: 4.10
    what mpg will u get with 4.10
    what other mods?
    Simple: 408 on steroids!
    single digits coming soon!
    i got a ls6 cam and converter i get about 17.5 with the stock 3.42
    probably wouldnt loose maybe 2 miles if that, but i'm just guessing here
    that's what one of the guys said i work with i need to work on my tune its cutting up in the high rpm's i ran a 9.2 1/8 and 2.06 60ft how much would 4.10 cut of my time
    Depends on if you are on tires that will hook up. Whats funny is my whipple would not carry me that fast when I had it. Worst mod ever.
    yea im on a tire m/t ET Street Radial i thought Whipple was a really good power adder
    Ls6 cam, ls6 valve springs, PTC converter 2800 to 3500 stall, locker, vette servo
    Quote Originally Posted by cory 5.3 View Post
    I spent way too much money on one. Pure garbage. No intercooler = 200 degree iat temps = no power. Even with meth it was worthless.
    i do pretty good on the highway, usually about 17 mpg if i swet the cruise otherwise its garbage.
    Jun 2007
    I dont use the cruise much ,but with 4.10s my milaege sucked.I saw quite a diff from 3.73s.good luck
