Results 1 to 10 of 14
Thread: Servo
    Feb 2008
    IOWA
    Servo
    I have a bone stk 4l60-e in my 00 silverado.. How good are vette servo's and what shold i call my local trans suplier and tell them what i need? and are they hard to put in?
    03 Silverado Extended Cab with 06 front end, Cai, Road Ripper 2000 Trans
    Pretty easy to do and cheap as well. Got both my sets of eBay from oregonperformancetransmission. Looks like you have extra room under there to work. Patience and attention to detail and anyone mildly mechanically skilled can do it.
    Feb 2008
    IOWA
    so do i just ask for vette servo is all?
    Yeah, it's a kit.
    Feb 2008
    IOWA
    thanks for your help, is looks easy enough
    Florida
    BE SURE TO SEAT THE RETAINER CLIP ALL THE WAY. This is the most important part. If it doesn't seat right when you shift to second most times it will bust the trans housing where the servo is.
    '04 Silverado RCSB with a crank bolt.
    You know your truck sounds good when cops ask you to get on it.
    Idle Clip
    Feb 2008
    IOWA
    good to know! thank you. Looks easy enough to do i hope. ill try after wrk
    Feb 2008
    IOWA
    i bought the servo from midwest transmission supply and didnt come with o rings! will new orings from a tranny shop off orignal servo work?
    Roma, Texas
    if its a 99-07 classic and the cats are still on its going to be harder. btw have a container handy to recover excess oil that you will need to lubricate the new corvette servo. you will need the corvette servo the kit and the red and the blue o rings.
    Florida
    Yes stock o-rings will fit. The outside of the servo is the same on any type servo you get. They just vary in shape to give more band pressure. Like I said just duoble, triple, and maybe want to quadruple check the retainer clip.
    Idle Clip
