Torque Converter Going?
Well i went to the trany shop today to have a sensor replaced that was causing the T/C to lock and unlock ramdonly(reading -30 degrees then switching back to 120 degrees)
When i came to pick up the truck the guy said that the T/C was going out beacuse he found a nice amount of metal shavings in the pan.
Is this just because the T/C is weak(stock 99(s10) 4.3 4l60e) and was going out beacuse of the added v8 power? Or the locking and unlocking caused by the temp. readings? Or maybe because i adapted the older gen 4l60e to the newer 5.3 causing some sort of problem?
1999 rcss/2002 5.3, Ls1 cam, Ls6 intake manifold, Ported TB, NelsonPerformance tune, CAI, MSD 8.5s, Sanderson shorties, Magnaflow X-pipe, Maganflow 2in2out muffler(no cats), FLT lvl4, Yank 3600, B&M tranny cooler, e-fans, 2/3 drop, Truetrac, Trickflow cover, 3.42 gears, Caltracs, A.R. Irocs 18"x8", NS-2s(245/40/18), Nitto 555s(275/45/18) two JL 10s, 2" cowl hood, SS mirrors, SS bumper cover, step shavers, and Alot from Current Performance
