Results 1 to 9 of 9
Thread: Help Needed!
    College Station, TX
    Help Needed!
    My friend has a 2003 volvo S80 Turbo that she broke a chunk of the knuckle off that connects to the balljoint and front left tie rod end. Its an awd with cv axles in the front. It looks like she is going to need a new driver side knuckle and Im gonna fix it for her.
    Know of any good places online that would ship em here quickly?
    If someone does find the part see if I can get it as cheap as possible. Would like to stay in 100$ range but if higher then ok.
    I am going to oreillys tommorow to check and see if they have it or can get one
    Help is greatly appreciated. (Note the she factor in this)
    Thanks
    College Station, TX
    EAD G
    jk
    Ive got a good online manual to look at while repairing. Seems to be very similar to my trucks knuckle assembly so I wont have to do worry about it too much. It says to use new bolts and nuts when installing the new knuckle, should I be safe and go ahead and order those too?
    Jul 2006
    College Station, TX
    You will do fine. You are good a handling nuts.
    2004 EXC Silverado 6.2L
    Mods:
    College Station, TX
    Quote Originally Posted by mongoose90584 View Post
    No, I just like using them to my advantage
    Did you get motor running or is that this weekend??
    See, even G has his funny moments. I literally LOL'd when I read that...
    And how does a fellow Aggie friend of Jon's know this?? Hmmm?
    Quote Originally Posted by Aggie View Post
    Yes. Better to be safe than sorry. Damnit--well, I can't use that saying cause you are pretty damn SORRY.
    Do what the manual says. Bolts and nuts are cheap.
    College Station, TX
    hahahaha you fawkers I sware!!
    Yea Ill def. get the new bolts and nuts with that..
    btw tyler...
    Cause IM the one thats gonna get a wee bit of tail outta this!
    Round Rock, TX
    [QUOTE=txarkitekt;243848]
    QUOTE]
    Why you gotta bring me in this?
    ha HA! I knew it.
