Results 1 to 10 of 11
Thread: 112 Radix+thumper Cam=??
    Question 112 Radix+thumper Cam=??
    NO WONDER HOW THIS COMBO WOULD WORK OUT??WHAT DO YOU GUYS THINK??SPECS ARE 219/233 .554' .537'
    I STILL GOT THE MAGGY SITTING HERE IN MY LIVING ROOM,I MISS THAT SCREAM
    ff_jeff Guest
    if the lsa on that cam is 109, then it will have 8* of overlap. It will work, but that cam will bleed boost, and hurt power. You need 0-neg overlap on the cam.
    Aug 2005
    The lope of the cam will beat the snot out of the drive gears of the blower.
    southside VA
    i dont think that combo would work to well lol....
    Pittsburgh, PA
    try it, i bet youll be surpised on how it works out. Ive seen the TSP Giant make huge numbers on a FI build, I seen a MS4 on a FI build both made numbers and ran strong. Ideal? no Numbers? yes
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    We need EC and IO numbers as well as LSA and duration to figure overlap.
    ff_jeff Guest
    I already disclosed the overlap.
    MidnightRider Guest
    not a good radix cam at all
    Feb 2004
    Western, KY
    I would try it, it's not like your buying the maggie
    Mods:
    Maybe STOCK
    "My lugnuts require more torque than your ricer is ever going to produce"
    Sleep: That Stuff Is Overrated
    "You don't care what it is, or who makes it, as long as they race it. You my friend are a true Gear Head!" (Drew Anderson)
    Who's the real culprit of Obeisity: video games because their scared of physical activities, or Pillsbury for being so delicious?
    Didn't see the EC or IO though.
