Results 1 to 10 of 13
Thread: engine code
    College Station, TX
    engine code
    anybody know if autozone or advance auto can check for codes?
    If you're just asking about just getting the code from you ecm, yeah they can do that. I've done it a few times at advanced.
    - Waiting for an lq9 swap - Super 40 center in dual out - battery swap to spare tire location - exhaust turndown -
    2
    Southwest AZ
    Quote Originally Posted by jcormier89 View Post
    Yes...I think they will even lend you the code reader for a small deposit
    2008 2WD Ext Cab 6.0 VMAX--MODS...CL MAF OnlyTUNE w/AFE CAI, Corvette Servo, Flowmaster 50 Series, Innovative LM-2 WBO2
    1998 S-10 4.3 V6-0411 PCM-Crower(Cam, Lifters, Rockers) JE Pistons, T-56 6 Speed, Innovative LM-2 WBO2
    [B]EFI Live FlashScan V2 & AutoCal[B]
    College Station, TX
    well...i took it there and the code reader says its the knock sensor...
    50 bucks more or less for a new one, is this something i can do myself? can i drive around like this for a while cause i really wont have the chance to replace it for another 2 weeks or so...
    Yeah you could definitely do it youself. Actually did mine back in october. They sit under the intake manifold.. and there's two of them.
    It wasn't too bad. And when you pull it all apart, you may find you need to replace your knock sensor wire harness. Your truck is a 2000 i would say replace it, my 99 knock wire harness was kind of brittle, and broke when I pulled it off. You might even need intake gaskets, they are reusable, but mine were toast were stuck the the intake.
    When it was all said and done, it cost me about 200 or so ,that includes computer time and something I broke.. sensors ($40 each), wire harness (about $45), intake gaskets (about $30), fuel line puller ($6) (3/8)
    2
    College Station, TX
    Next time you have a code let me know I can scan it for you with either my plx gauge or my OBDII Scanner. Autozone here sometimes takes forever to scan stuff they are lazy
    College Station, TX
    im not gonna break soemthing else if i drive around for 2 or 3 weeks will i?
    Fort Worth, Texas
    Should be ok... When mine went bad the code would come and go for a few days at a time. Then when the code finally stayed on it took me another week or so to get the time to do it, haven't had any problems.
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
    Only reason I jumped on doing mine are the amount of miles on my engine.
    2
    Knowing the code is 1/10th the way to a fix in most cases although the advice in this topic looks OK. Replace both sensors, the harness, and the intake gaskets IF the wiring and PCM are OK.
    Do a search.
