Thread: got a leak
    Apr 2003
    Wylie, TX
    I have a leak on the passenger side of the truck. When it rains, don't even have to be driving, I get a puddle of water under the carpet and under the door sill. Has anyone else had this problem and been able to get it fixed. It is realy starting to bug me. Thanks in advance for any help you can provide.
    Randy
    RChevy.48
    2001 Silverado RCSB 4.8L
    Current Mods
    Flowmaster Exhaust
    LT1 Fans
    vette cam sitting in garage
    Jasper, Ga.
    Check the rubber boot that hold the wiring to the door. You may need to remove the door to fix it if that is the cause.
    1999 Silverado 1500 Ext. cab Red 2/4 hotchkis drop & swaybars, bilstein stocks, AR626 & 404 Nitto's, Yank converter, ASM headers, ASP underdrive pulley, Taylor wires , free mods VCN 2000, Nelson Performance tuning
    2002 Red WS6 M6; Flow master K&N
    Apr 2003
    Wylie, TX
    you mean where the wires for the speakers and lock and window switches. Damn I hope I don't have to take the door off.
    RChevy.48
    Current Mods
    Flowmaster Exhaust
    LT1 Fans
    Jasper, Ga.
    Yes. I need to remove the door to seal up the other side. Three bolts to remove the door if you need to. Have someone hold it straight and rest it on a 5 gallon bucket, so I could seal the front side. Try to get it thought the door jam. Hope it helps and or works for you.
    Paul
