Nelson LS1 Fan Harness Problem
Ok here is the situation...
*R/L from drivers seat perspective*
AC Off/ Truck not at operating temp (Both Fans Off)
AC On/ Truck not at operating temp (R Fan on High, L Fan off)
AC Off/ Truck at operating temp (Both Fans Off) <--Very Bad
AC Off/ Truck at operating temp (R Fan on High,L Fan off) [The left fan will sometimes seemingly turn on low, seems that it happens some times and not others]
Put connection from R Fan to L Fan and turned on truck and AC and L Fan ran on high. So I know that both fans work. When I received the Kit one relay was damaged so I replaced it with one that I had. Do you know of any way I could test relays to see if they are operating properly? Is there anyway I could have installed the blue wire wrong (it snapped into place when installing seems pretty fool proof) and I am sure I am connected to the right green AC wire (since that is the only thing that is working properly).
Thanks guys, was sitting in the staging lanes tonight and my truck almost over heated on me. Got 2 runs in and the truck only ran 2 tenths faster (This is after a tune LT headers e-fans) very disappointing night.
MKader17
- You may not post replies
- You may not edit your posts
