Thread: Abnormal brake prob
    Crossett,Ar
    Abnormal brake prob
    I have had to replace at least one set of pads on everything I have ever driven. But my truck has thrown me a new one. Situation starts as im driving about a 130 down a highway and EVERY light on the dash comes. Says my parking brake is on and all kinds of crap. check engine so on and so on. Says on the display to service brakes now. Well i pull over cut the truck off turn it back on and it acts like nothing ever happend. SINCE then if I come to a stop really fast the back driver side brake smokes like it is on fire. Visually the brake pads look fine (note this is only lookin down not taken off and checked) and i jacked the truck up and it isnt locked up or anything. Dont see anything leaking on it either. Any ideas or anyone have this problem before?
    wichita falls, tx
    sounds like an abs problem....maybe
    Intro Radicalli's
    Hutto TX
    Smoking brake = BIG problem, I am sure you will find it once you look for it. And don't drive 130 in the meantime
    1991 Silverado ECLB
    LM7-T56
    wichita falls, tx
    it sound like one of the pads fell and its dragging on the drum i have seen those springs break before because is just one big horseshoe clip/retaning spring
