put in my tune this morning,pretty easy install no problems except i had to the security relearn and it fired right up after the 3rd go around.
next of course i had to go try it out,the results are better than what i had with the hpp3,but not quite what i had anticipated.ill give it some more miles before i make up my mind on it completely.also had allen try to get rid of an annoying cruise control effect that i think is a result of my manual trans but with no luck,same as before.
- You may not post replies
- You may not edit your posts
