Results 1 to 7 of 7
Thread: cam suggestion
    wichita falls, tx
    cam suggestion
    i need some help on a good cam for a lq9 thats not going to give me alot of idleing problems but will still give me some lope and a pretty good power band.
    IT is a automatic with a 2600 stall.
    thanx
    Mar 2006
    Mesquite
    I would try something around a 220/220 on a 112 lsa (click):
    The Texas Speed 220/220 .581/.581 Camshaft With Your Choice of Lobe Seperation.
    This camshaft features Comp Cams XER lobes! The XER lobes have been proven to make big horsepower & torque thanks to their aggressive ramp rates & healthy lift.
    1200-6200 RPM Power Band; This is an excellent performance camshaft with a smooth idle! Custom tuning for automatic cars required
    This camshaft typically gains approximately 30-35rwhp!
    wichita falls, tx
    i heard that that much lobe soperation was hard to get it to idle right
    Mar 2006
    Mesquite
    Nope...maybe 110 would be a challenge, but even a 110 can be tweaked by a good tuner. If you're wanting lope, I would get the 112.
    112 LSA is not hard to tune. All you need to do is raise or lower your engine idle RPM to even out the idle...
    BUT.. if your wanting ALOT of lope, go with the 110 haha
    Motor-msd coil packs, bbk 85 mm throttle body, volant cold air intake, granatelli solid core wires, jba ceramic coated shorty headers, magniflow high flow cats, jba cat back. Suspension- 5/7 drop with foose nitrous 6 22's with nitto invos, bear eradispeed rotors. System- Pioneer avic z1 with 2 sets of kicker rs componets, 2 kicker L7 10s uder the seat, kicker 1500.1 and 350.4, clarion headrest monitors. body mods- shaved tailgate, rollpan and stake pockets, HD hood painted bumper cap, painted rear door handles out of a suburban, and of coarse lambo doors. future upgrades are airride and a lq9 swap and 4 L7's in a bed cut
    get rid of the shorties get long tubes, doesnt matter what cam you get with shorties youre still leaving alot on the table, stick a tr224 in there and be happy... then again if your not planing on doing any head work, then go with a 218/220 or something in that range..
    Simple: 408 on steroids!
    single digits coming soon!
