I was installing my custom engine harness. I needed to separate some of the harness bundling to get enough length to the crank sensor. I accidentally cut one of the crank sensor wires. I repaired the wire by splicing in a two inch piece of 18 guage wire, soldering it and heat shrinking the area. The original wire is about 22 guage which I didn't have available. Is the larger diameter wire going to throw off the sensors capability to deliver the proper message to the ECU?
