SO I have longtubes with Off road y pipe, is it ok to install the sensor right where the ypipe brings the two sides together, or is that too far from the engine, would I need one for each side?
best place would be the header collector if possible just make sure you put it in at a slight angle and not at the bottom to avoid any condensation
2007 SRT8 Jeep Grand Cherokee
So it is good enough to just monitor one bank?
yeah your fine just keeping an eye on one side
Thats how I roll
2006 GTO M6 Brazen Orange
2006 Silverado CCSB Duramax
Allen, any input on this one?
Cool, by reading the Narrowbands it seems I am running ok around 875 mv at WOT on both banks. So I will install the Wideband on the driver side header collector. The good news it it looks like I have plent of room to weld in the bung without removing the header. I found this chart somewhere for reading narrowband o2 mv's if anyone is interested.
Gauge READING FULL THROTTLE AIR/FUEL RATIO
.000 17.0:1
.100 17.0:1
.200 16.0:1
.300 15.5:1
.400 15.0:1
.500 14.7.0:1
.600 Dangerously Lean 14.6:1
.700 Getting lean 14.5:1
.800 Max power(Lean) normally aspirated 14.2:1
.875 Max Power normally aspirated 13.5:1
.900 Max Power (Rich) (NOS,blower,Turbo) 13.2:1
1.000 Very Rich 12.5:1
I would STRONGLY encourage you guys to NOT use your narrowband O2s to log your AFRs. They are only good for telling your PCM to run at stoich. Here's a graph I made of mine in relation to my wideband awhile back. You can see why it would be incredibly inaccurate to rely on narrowband O2s for precision tuning. There is a ton of noise in this chart.
Why no narrowbands they make for a pretty light show-LOL
