Something must be wrong! I have a 02LS! with 4L60E, 3.73 gears, 30.6" tires and locking diff and I can spin both tires all day long. My truck feels strongest in low gear and pulls real hard through all the gears and I'm running the stock converter. Have you tried to shift to low gear and take off vs just leaving it in drive. Maybe it isn't shifting into 1st and it is taking off in 2nd. Count your gears as it is shifting and see if all four gears are there. When I first drove mine I forgot to hook up one power wire and my truck felt real slugish and took off from 2nd gear unless I manually shifted it. Just some thoughts.
