My fuel pump is rated for 55 -62 psi. I am getting 55 psi fuel pressure through the regulator. Am i using a fuel pump that is a little weak ( meaning should I get one that has a higher rated psi) or is it more likely that I am not getting enough electric current to the new pump I have installed?
Thanks
