Originally Posted by
SCIV
Okay I tried to search, but I didn't find anything I liked.
I need a cam selection for my 408. I am going to run NA for a year or so, and then I can swap for a more suitable FI cam later.
EC 1/2 ton truck weighs 5,070 with me in it, 3.73 gears with 32" tires (305/50R20), stock stall. Daily driver. CR is 9.6 on the 408.
I don't need a rediculous lope, so I would like to keep the LSA around 114.
Let 'em fly...
SCIV
you can run my cam N/A or FI. 220/220 .581/.581 on a 115. It is a good cam Pulls mid to high end. If you already have a stall it will be perfect.
Foggy has the same cam. Get with Allen to make sure.
Jamest
12 Sec. Club! SOLD
SOLD***
