Hi Guys,
Its been a while and I'm feeling a little better about myself after reading the following article, but I'm not sure I should be feeling this good. Can someone help me understand the weight-to-power ratio of HP a little better? I'm still pretty unclear on it.
Anyway - back to the article:
Truckin' No. 9 Volume 33, July 30, 2007 (out on sale now). "To hell and back" (2007 Harley-Davidson F-150) page 38,39 + 55
(Granted, this is a 4-door P/U and completely stock):
pg 38 "And the bad-boy Harley gives Ford a tagline that it can now punctuate with a bad-ass 450hp 500lb-ft supercharged powerplant......"
pg 39 "Our time on the dyno was troubling. Our first power run resulted in numbers far lower than the 380hp that we had expected at the wheels. We let the truck cool down and gave it another shot, getting only 337 hp. The guys at Livernois said they couldn't get any more out of it, without discarding th rather restrictive airbox or doing a custom tune. We did confirm on the dyno, not the street, that the speed limiter kicks in at 120mph".
pg 55 " This truck came with a supercharged 5.4L V-8 that cranked out a respectable 445 hp and 500 lb-ft... KNowing that the factory speed limiter on the Roush was activated and set at around 95mph, we didn't bother taking the truck to a 1/4mile dragstrip.........So, we took the Roush to a nice patch of asphalt that we know, where we tested the 0-60 performance. Out of five runs, we twice made a time of 6.76 seconds."
See sig for my adders and note that its been a long-standing-well-known issue that my vehicle is in DIRE need of some sort of tuning beyond what even some pretty good tuners can tune. They also suspect I have a problem between the TPS and injector wiring harness (this is evidenced by poor A/F ratio until about 2800rpm, then it steadily evens out until about 6200rpm). Ran a 14.6 1/4mile when it was 105 degrees and ran a 14.6 in 88 degree weather.... a little bit too consistent for the amount of temperature change. I pulled of a 0-60 time of 6.2 (not a 60' time - he he)
So am I
Is it that hard to make rwhp out of a truck? Should I feel more impressed with my truck being that its N/A and tapping into 360rwhp? Understandably, I'm not trying to turn it into a dyno queen and obviously have my priorities right I feel, since I'm trying to get the ET down and disatisfied with it.
Sorry this was so long....just trying to understand.....thank you for any feedback.
93 Ext Cab w/ 99' LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
Edel IAS shocks, Hotchkis front/rear antisway bars, 3.73 Axle w/ 8.5" -10-bolt w/ Eaton Posi
