Results 1 to 10 of 10
Thread: boost gauge problems
    well im noticing that my boost gauge doesnt want to go into boost, it goes into vacume, and when i wot the needle barely moves slowly into boost but not enough to turn on my meth light with is set at 3psi, i checked the fittings and hosed and everything looks fine, its been working, but i notice it today that it dont
    Whoop Ass Racing
    Radix W/Intercooler
    E.T is a 12.79@105mph
    http://i25.photobucket.com/albums/c5...sracer/sig.jpg
    Jan 2006
    <div class='quotetop'>QUOTE(whoopassracer &#064; Mar 24 2007, 05&#58;17 PM) [snapback]87189[/snapback]</div>
    SOUNDS LIKE A VAC. LEAK SOMEWHERE. LOOK AT YOUR MAP SENSOR, YOU MAY HAVE BLOWN IT OUT? CHECK THE VAC FITTINGS TO MAKE SURE NONE HAVE COME LOOSE, ALSO TRY THE VAC LINE RUNNUNG TO THE METH BOX IT MAY HAVE BLOWN OFF. MINE DID THAT ONCE.
    I HOPE YOU FIND IT.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Dec 2003
    Newark, Tx.
    check for a kink in the line somewhere
    its like im around 18-20vac then WOT and complete stop and zero no further maybe 1or 2psi
    Whoop Ass Racing
    Radix W/Intercooler
    Jan 2006
    <div class='quotetop'>QUOTE(whoopassracer &#064; Mar 24 2007, 10&#58;53 PM) [snapback]87201[/snapback]</div>
    IS THE TRUCK RUNNING THE SAME? IF IT IS, THE GAUGE MIGHT BE BROKE? IF YOU DON&#39;T FEEL THE BOOST AT WOT THEN A VACUUM LEAK, IF YOU DO FEEL THE FULL BOOST AT WOT, THEN THERE IS A PROBLEM. IS THE METH LINE TIED INTO THE GAUGE LINE? MY GAUGE IS TIED INTO THE METH VAC LINE. I JUST DON&#39;T KNOW? DO YOU HAVE A CAN OF B12 SPRAY? SPRAY LIGHTLY AROUND THE VAC LINE AND SEE IF THE IDLE OF THE MOTOR ADVANCES, THEN YOU WILL FIND THE LEAK. IT MAY NOT BE THE SAFEST, BUT IT WORKS, I USED TO DO IT ON MY OLD 67 MUUUSTANG BACK IN THE DAY.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Apr 2005
    Check your crank bolt to see if it is tight.
    Gone, but not forgotten!
    well i checked all vac lines and no leaks, and i have the map, meth, and boost line running through the same line where i get boost,
    do u guys think my crank pulley is spinning
    Whoop Ass Racing
    Radix W/Intercooler
    Apr 2005
    <div class='quotetop'>QUOTE(whoopassracer &#064; Mar 25 2007, 02&#58;50 PM) [snapback]87231[/snapback]</div>
    Did you check the crank bolt? That will answer your question.
    the bolt was freaken tight, i didnt even have the torque to take it off
    Whoop Ass Racing
    Radix W/Intercooler
    its the gauge
    Whoop Ass Racing
    Radix W/Intercooler
