I'm in the process of instaling the Boost cooler on an 03 GMC HD 6.0L with a whipple pumping 10lbs of boost. The problem I'm running into is the directions and parts don't actually match ie the vacume port on the VC is blocked and the barb for the line is missing and the directtions don't reflect this change. It appears that the MAFT that comes with the kit uses a signal from the MAF to adjust things. The problem I'm running into is that there are 4 wires comming off the MAF... which one is is the output signal so I can tap into that wire? Yes I realize that it would be easier calling Snow but since this is Saturday of a 3 day weekend they may not be in the shop/office ( I already tried calling). Any help would be helpfull.
Randy
