Results 1 to 10 of 10
Thread: gapping the ngk tr6's
    like the title says do u guys have these plugs with the radix setup and what would be the best gap for them over on pt.net there's some gapping them at .032-.028. would this help or not any thoughts
    Whoop Ass Racing
    Radix W/Intercooler
    E.T is a 12.79@105mph
    http://i25.photobucket.com/albums/c5...sracer/sig.jpg
    May 2004
    Yes, you want to keep a smaller plug gap w/forced induction. A smaller gap will ensure ignition in denser air/fuel mixtures from forced induction.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    <div class='quotetop'>QUOTE(whoopassracer &#064; Jan 17 2007, 07&#58;48 PM) [snapback]80158[/snapback]</div>
    like the title says do u guys have these plugs with the radix setup and what would be the best gap for them over on pt.net there&#39;s some gapping them at .032-.028. would this help or not any thoughts
    .035-.032 in that range is good
    Aug 2005
    St. Anthony, Indiana
    I gapped mine either .030 or .035. I don&#39;t remember which one it was for sure. Don&#39;t go any wider than .035 or you might blow the spark out.
    sprayed99 Guest
    35 all the way
    Dec 2005
    .30 FOR FORCED INDUCTION MAYBE .28 IF GOING TO 10 PSI OR MORE.
    http://i76.photobucket.com/albums/j1...o/789547ee.jpg
    1999 Silverado LS RCSB 5.3 Liter (16.02@83.5 bone stock) (with mods ??.?? @ ?)
    STS Turbo Kit (5 psi), GT67, STS Intercooler, 42lb/hrs, 255 Pump, 212 216 Comp Cam, Nelson STREET Tuned, Eaton LSD, 4.11&#39;s, Phoenix ReTrans Stage 3 4L60E, 160 t-stat, B&M Supercooler.
    Apr 2005
    <div class='quotetop'>QUOTE(Turborado &#064; Jan 18 2007, 10&#58;02 AM) [snapback]80204[/snapback]</div>
    I am at .028 for 10psi
    Gone, but not forgotten!
    Oct 2005
    drinking your alcohol
    yep i did mine 35 but i dont have a blowy thingy ... but i have always heard use a smaller gap for F/I
    DamnYankee: my nana failed
    Jan 2006
    .35 HERE.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Apr 2005
    <div class='quotetop'>QUOTE(Jamest &#064; Jan 18 2007, 11&#58;23 AM) [snapback]80221[/snapback]</div>
    .35 HERE.
    JAMEST
    Allen had me lower mine to .028
    You might want to see if you should be at .030
