what do i have to do to remove the egr on my 2000 silverado any problems if i do
00 silverado 5.3, 2005 caddy clip,mods asp pulley,e-fans,3.73s,custom intake,jba shorties,hypertech=14.9@95
very easy, there is a kit you will need. Go to ls1speed.com. Look under 02 ls1 because they dont list the trucks. You will need the manifold plug and the header block off plate. That should do ya, if you have a custom tune you will need to have the egr codes turned off, doesnt hurt if they are on though.
Chris
<div class='quotetop'>QUOTE(chrisj6 @ Mar 19 2006, 11:06 PM) [snapback]47458[/snapback]</div>can i get the intake plug at a local dealervery easy, there is a kit you will need. Go to ls1speed.com. Look under 02 ls1 because they dont list the trucks. You will need the manifold plug and the header block off plate. That should do ya, if you have a custom tune you will need to have the egr codes turned off, doesnt hurt if they are on though.
Chris
what does removing the egr do with performance? or just in general?
yeah i think the dealer does have a similar kit.
It doesnt do anything to performance, its just there to help keep down emissions.
Chris
<div class='quotetop'>QUOTE(duckysbht @ Mar 20 2006, 09:11 AM) [snapback]47487[/snapback]</div>The egr recirculates innert gasses from your exhaust back into the combustion chamber. These gasses do not burn because they don't contain any oxygen, they help to keep comb. chamb. temps. down in turn helping with emissions. Although I think most egr valves are closed at WOT, deleteing it can't hurt performance as long as you are using good fuel.what does removing the egr do with performance? or just in general?
[1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
They also help dirty up the inside of the intake manifold with the carbon. The carbon sticks to any oil residue caused by the pcv valve. My 01 manifold was very filthy!!![]()
2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
Sorry to dig up a dinosaur here, but as I recall, the 2002 Silverado does not have an EGR valve, is that correct?
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
<div class='quotetop'>QUOTE(BlenderWizard @ Jan 22 2007, 08:10 PM) [snapback]80813[/snapback]</div>nope no egr on my 02 so i tink u r rightSorry to dig up a dinosaur here, but as I recall, the 2002 Silverado does not have an EGR valve, is that correct?
04 Grand Prix GTP
03 Z71 wanting a Turbo ,Stall, and Tune BAD
THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
2002 + did away with this sensor, you are correct.
