I'm working on my VE table and getting pretty close to where I want it... only thing is, my table is starting to have some dips, do I need to worry about that?
I'm using HP Tuners, any comments/suggestions are welcome.
2001 Silverado Z71
2001 Z06 cam and springs, LS1 electric fans, S&B intake, Magnaflow cats and Corsa exhaust.
No wideband... Runs great and pulls hard, just wanted to double check to make sure this was 'normal'.
<div class='quotetop'>QUOTE(use2bfo @ Nov 16 2006, 04:39 PM) [snapback]73747[/snapback]</div>You using wideband or narrow , wideband is better for VE tuning , narrow is to iffy (changes to much).
LTFT and STFT averaging , is ok but a LC-1 or LM-1 is better , how does it run ?
2001 Silverado Z71
Yeah, not sure how else to do it though without a wideband.\
Tempted to try ChrisJ's just because they look so nice lol!
2001 Silverado Z71
Thanks... That's exactly what I've been doing. What I didn't realize is how much I can clean up (smooth) the table without changing the numbers much.
2001 Silverado Z71
Do you have the maf enabled?
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
No I don't....
<div class='quotetop'>QUOTE(farmtruc @ Nov 19 2006, 01:01 AM) [snapback]73882[/snapback]</div>Do you have the maf enabled?
2001 Silverado Z71
<div class='quotetop'>QUOTE(Lucky @ Nov 19 2006, 07:11 AM) [snapback]73885[/snapback]</div>You're doing fine then, keep it up, the dips are ok as long as data being logged looks good.No I don't....
Get a wideband someday and you can fine tune it.
good luck,
allen
Nelson Performance
NP on Facebook
Youtube Channel
Ok thanks... Might have to invest in one of those soon here.
<div class='quotetop'>QUOTE(farmtruc @ Nov 19 2006, 10:04 AM) [snapback]73893[/snapback]</div>You're doing fine then, keep it up, the dips are ok as long as data being logged looks good.
good luck,
allen
2001 Silverado Z71
Since your asking about your VE Table post some pics of it so we can see the dips and spikes.
That is your spark table you posted above?
Sorry, bit of confusion there...
While dialing in the VE I noticed knock retard so my priority changed to getting rid of that.
2001 Silverado Z71
