Results 1 to 10 of 12
Thread: FLT TRANS
    Jan 2006
    I HAVE JUST INQUIRED ABOUT A 4L80E TRANS. FROM FLT LEVEL4. I HAVE A DUMB QUESTION. CAN THE FIRST TWO GEARS BE CHANGED OUT TO MATCH THE GEARS IN A 4L60E? THE 4L80E HAS A 1ST GEAR F 2.48 TO 1 AND A SECOND GEAR OF 1.48 TO 1 WHILE THE 4L60E HAS A 1ST GEAR OF 3.059 TO 1 AND A 2ND GEAR OF 1.625 TO 1. IS THIS FEASABLE? IS THIS WHY IT TAKES SO MUCH HP TO TURN A 4L80E?
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Oct 2005
    drinking your alcohol
    <div class='quotetop'>QUOTE(Mister P &#064; Dec 13 2006, 02&#58;27 PM) [snapback]76231[/snapback]</div>
    If you are under 600 lb-ft of torque I would stick with the 65e, because of the better 1st & 2nd ratios; those 80e&#39;s eat a lot of hp.
    Mr. P.
    this is what was in another thread down in mechanical talking about either an 80e or 65e from FLT... i dont know if that helps... but it kind of pertains to what your talking about&#39;
    as for being interchangable, i wouldnt know
    DamnYankee: my nana failed
    Jun 2004
    george west texas
    they do have diffrent gears for the 80e that they use in motor homes...might talk with vince and see if they carry them ....
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Nov 2006
    Plano, TX
    Yes custom planetary systems are available for the 80E, and they are NOT cheap.
    Mr. P.
    Jan 2006
    <div class='quotetop'>QUOTE(Mister P &#064; Dec 14 2006, 01&#58;47 PM) [snapback]76323[/snapback]</div>
    Mr. P.
    DO YOU KNOW THE GEAR RATIOS? I WOULD LIKE TO MATCH THE 4L60E/65E. ANYONE KNOW?
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Jun 2004
    george west texas
    John Kilgore&#39;s planetary gear set is the 2.75 or the 3.00 first gear. 2nd gear also changes. It will be almost identical to what the 60e is.
    the 2.75 gear set is available from any GM dealership its put in the RV 80e&#39;s...
    San Marcos Texas
    <div class='quotetop'>QUOTE(bud8fan &#064; Dec 14 2006, 04&#58;11 PM) [snapback]76336[/snapback]</div>
    That is cool&#33; I didn&#39;t know that gearing was available.
    Jan 2006
    THE 3.0 I THINK IS IDENTICAL TO THE 4L60 3.09
    THANKS,
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Does it really matter with a higher stall converter and all that torque you have, hahah.
    Sounds like a good solution James. Is your current one giving out or are you just planning ahead?
    see ya,
    allen
    Jan 2006
    <div class='quotetop'>QUOTE(farmtruc &#064; Dec 21 2006, 08&#58;24 AM) [snapback]76946[/snapback]</div>
    see ya,
    allen
    PLANNING AHEAD. HEE HEE. JUST FOUND OUT THAT MY CERTAIN TRANS WILL ONLY HOLD THE GEARS THAT ARE IN IT. THE NEWER ONES HAVE THE ABILITY TO CHANGE THE GEARS. I HOPE THE 3200 YANK STALL DOES THE TRICK?
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
