2000 Sierra 2500 HD. 408 (11-2007) Whipplecharged, Big (18x24x4) FMIC.
neat picture show, I am new at that stuff
New at picture shows or the intercooler stuff?
picture stuff, I am only dreaming of FI
Check out my post at PCM Tune & Dia
interceptor POD
<div class='quotetop'>QUOTE(metalchips @ May 27 2006, 11:20 PM) [snapback]54198[/snapback]</div>Some of the things you can do with an Apple computer and a .Mac account.picture stuff...
Very nice!
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
<div class='quotetop'>QUOTE(MikeGyver @ May 27 2006, 09:11 PM) [snapback]54188[/snapback]</div> Hey, here are the PN's for the IAT sensor and Grommet you needed from the other post.
IAT Sensor: PN 12160244
Grommet: PN 24504388
BTW, I decided to mount the sensor on the whipple hat, I registered about 210deg intake temps from the whipple, HOT!!
When the alky spray activated it dropped to about 105degs, timing went from 5-8degs to about 20degs, huge difference, no KR detected under either condition.
good luck on your project.
allen
Nelson Performance
NP on Facebook
Youtube Channel
Thanks for the PNs, AN. What part is the Whipple "Hat"?
<div class='quotetop'>QUOTE(MikeGyver @ May 31 2006, 04:39 PM) [snapback]54404[/snapback]</div>No problem, the parts are cheap too.Thanks for the PNs, AN. What part is the Whipple "Hat"?
I just call that part that replaces the TB on the intake a hat, I dunno.
allen
Nelson Performance
NP on Facebook
Youtube Channel
<div class='quotetop'>QUOTE(farmtruc @ May 31 2006, 02:31 PM) [snapback]54375[/snapback]</div>I was worried about the meth spray hitting the IAT and giving a false reading. That is why I mounted the IAT in the manifold. So now I'm (probably) getting a false reading from heat soak. Oh, well. When it was running last Hell's fire (summer), I wished I could get as much as 5-8 deg. With KR, I was seeing 0-2 degrees. Here's an example from a log I am looking at: 151 IAT (with methanol), 174 ECT. 100 TPS from 3149 to 4194 rpm, 8 degrees KR, 1.5 deg. advance. False KR? We'll see with this '02 computer you sent.
If you're getting no KR, then even if the spray is hitting your sensor, 20 sounds safe.
Is that what kind of timing we're looking for under boost?
