Results 1 to 10 of 26
Thread: Took the TT Truck to the track...
    Dec 2004
    Andrews, NC
    I made it to the track this past weekend and was pretty happy with the results. I met up with dave(quicksilverado) and dusty on saturday at commerce. It took me a couple times to learn how to launch with the turbo but I still couldn't build any boost off the line. I could only manage a 2.2sec. 60'. I tested the boost the day before and could only run 13psi because I ran out of fuel pump but it still pulled pretty hard. So all runs where at 13 psi. My best time was 12.06@121. That mph is an easy 11 sec run with a beter 60' because that run was a 2.2sec 60'. Thats ok though because I just ordered my 2-step from Snergy. Heres the video my girl friend took. http://video.performancetrucks.net/video/b...865000b1a3a.htm
    2002 GMC Seirra scsb, 5.7LS1, Twin 62-1 turbos, Compcam 222/218, 4l80e, and Hptuners
    2006 GTO Black/Red, 6.0 M6, 238/240 cam, SW LT, exhaust & bolt ons = 438rwhp411rwtq!
    Apr 2005
    Sweet numbers man!
    Gone, but not forgotten!
    Feb 2005
    Nice Run, 11's will be easy for you.
    2001 GMC Silverado
    Stock Bottom End LQ9, MS3, Stock 317's, Victor Jr, Aron's Elbow, 90mm TB, 1 7/8 TSP headers, FLT 4L80-E, Rossler Trans-Brake, 3600 PI TQ, 4.10's, 31" tire. Nitrous Dave System with Zex plate. On 150 shot 10.53 @ 128MPH 1.51 60'
    Old Setup = Trick Turbo Kit Tuned/Installed By Nelson Performance 10.78 @ 127.08 1.62 60'
    why arent you able to build boost off the line?
    May 2003
    Idabel, OK
    dude that is sweet and definitely a sleeper. If I was rolling around in the vette I would not even consider you competition, but that would be a big mistake for me
    on the truck man! Get a line lock and or bigger stall and you should be able to get those RPMs up some more before leaving the line. With a 1.6 or so 60ft you will be low 11s!!!!
    Where you from?
    99 C5 cam/boltons 400rwhp
    10 Sierra CC 6.2
    03 Suburban 5.3
    Jan 2006
    Sweet Numbers.
    Fix that 60 ft and you will be haul'in. That is my problem the 60ft.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    May 2006
    Waco TX
    Was that on slicks?
    Aug 2006
    McCurtain County, OK
    <div class='quotetop'>QUOTE(stngh8r &#064; Oct 25 2006, 12&#58;35 PM) [snapback]71069[/snapback]</div>
    on the truck man&#33; Get a line lock and or bigger stall and you should be able to get those RPMs up some more before leaving the line. With a 1.6 or so 60ft you will be low 11s&#33;&#33;&#33;&#33;
    What size stall are you running and what gears? Get that 60ft. down and you will be mid to low 11&#39;s easy.
    2004 ECSB Silverado LQ9 6.0L Superchips;14.0 @ 96: 4900lbs of Fun
    69 Chevelle Coupe LS1/A4 swap
    Feb 2005
    Austin, Texas
    He cant build boost cause he has twin 62s on 346CI motor
    San Marcos Texas
    Hell mine won&#39;t build much boost off the line either. I figure better than no traction.
