Thread: electric fans for improved performance?
    May 2003
    Idabel, OK
    Thumbs up
    I want more performance and to take a load off the engine, but not at the expense of cooling, power & reliability. I know that electric fans are generally thought of as one of the must have boltons for the added performance by decreasing the load on a engine, but I was just curious about any actual before/after results from this mod. I have already purchased some used electric fans, but havent installed them yet. After reading the below article I am thinking that for my big 460 Ford engine, I may need to stick with the fan that can pull the most air and cool better??
    Also, If you use a flex fan(in an effort to reduce drag), do you still use the clutch or is it just directly attached to the pulley?
    fan writeup/comparison
    thanks for your replies
    EE
    99 C5 cam/boltons 400rwhp
    10 Sierra CC 6.2
    03 Suburban 5.3
    Aug 2006
    McCurtain County, OK
    Linky no worky for me....
    But I am considering fans for my '04, and was curious if anyone has actually tested hp/ft. lbs gains on a fan install, and like STNGH8R said have you had any cooling issues?
    2004 ECSB Silverado LQ9 6.0L Superchips;14.0 @ 96: 4900lbs of Fun
    69 Chevelle Coupe LS1/A4 swap
    May 2004
    I&#39;ve seen as much as 12 hp results from electric fans. I put them on my truck and love them. No cooling issues either. JMO
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    I have some, and the motor dosen&#39;t seem to have to work as hard as it would before. The temp. stayed the same or went a bit lower.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    May 2003
    Idabel, OK
    Post
    link patched up. Keep in mind that the information in the link is from a offroad point of view.
    Thank you for the replies.
    10 Sierra CC 6.2
    03 Suburban 5.3
    DBYRD Guest
    posted results from a tbss last night, do a search and u can find it. efans r the way to go.
