I'm eventually going to do both, just wondering which to do first:
Underdrive Pulleys or ported throttle body?
<div class='quotetop'>QUOTE(Moze @ Aug 16 2006, 04:38 PM) [snapback]61375[/snapback]</div>ive thought about doing the UD pulleys but then i realized i would want to also replace the ac pulley, but then my ac wouldnt run very cold at low rpms. so i decided not to.I'm eventually going to do both, just wondering which to do first:
my a/c does fine with the underdrive pulley, why would you want to change the a/c pulley??
http://i17.photobucket.com/albums/b9...5831PM-2-1.jpg <--- TimeSlip
RCSB 5.3 N/A 12.31 full boltons,H/C,4.10s,3800 converter. SOLD
04 GTO
Both Tuned By: ME
Fella's, I have heard that these pulleys mess with your alternator. Is that true? If so ,by much?
2000 Chevrolet Silverado, 4.8L, K&N polished intake, 4.10 gears, 20x9 KMC SS on front, 22x10 on rear, Dual style pillar gauges, steel cowl hood, 2" rear drop shackles, true duals w/IMCO extreme mufflers w/dumps at rear end, SLP headers. Cam and nelson tune soon to come!!!!!
i just thought that with a smaller pulley it might take more revolutions to turn the ac pulley making it blow colder, but its just something ive heard.
I think the compressor is going to run only long enough to reach a certain pressure then the clutch will disengage. So it doesn't matter how fast it is turning, it'll run as long as is required and then shut off.
Moze I'd port the TB first since it's basically free and the pulleys are like $200.
[1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
<div class='quotetop'>QUOTE(Moze @ Aug 16 2006, 04:38 PM) [snapback]61375[/snapback]</div>How much do you expect to get out of this combination?I'm eventually going to do both, just wondering which to do first:
93 Ext Cab w/ 99' LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
Edel IAS shocks, Hotchkis front/rear antisway bars, 3.73 Axle w/ 8.5" -10-bolt w/ Eaton Posi
There is a difference between porting yourself and having one done by someone that knows something about air flow. I have never sold one to someone that couldnt feel the difference.
throttle body at top of page.
<div class='quotetop'>QUOTE(trtturbo @ Aug 17 2006, 12:19 PM) [snapback]61468[/snapback]</div>Does it make a difference on a DBW FI setup?There is a difference between porting yourself and having one done by someone that knows something about air flow. I have never sold one to someone that couldnt feel the difference.
[/b]![]()
Gone, but not forgotten!
