Results 1 to 10 of 13
Thread: Best way to lower VHO?
    Feb 2005
    Round Rock, TX
    What have you guys done? new keys or spindles in front? How is the ride with lowering keys? Mcgaughy spindles I know work great on reg 1500,s but my VHO has torsion bars.
    Thanks Corky
    Sep 2004
    I've heard that you can lower your tire pressure to bring it down a little (grin).
    Just kidding! SCIV have you done any research on this? I know McGaughy makes a spindle for it. I would think that would be the place to start.
    No more trucks, but this is what I used to have. 2000 GMC Sierra, 6.0L-LQ4, Built 4L60, LS6 Cam, The Other Guys Headers, 3 inch exhaust and 7 chamber flowmaster, 43lb injectors, Nelson Tuning, Drop - 3/4 McGaughys Spindles, Bell Tech Shackles & Hangers. Best time 13.59 @ 106
    May 2004
    I would have to agree with rosscob, McGaughy or I think Ground Force has one.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Aug 2004
    Magnolia, TX
    you can crank the t-bars to lower it up front, then shackles, hangers or leafs for the rear. they actually have different keys you can buy that will lower the front
    Sep 2004
    <div class='quotetop'>QUOTE(2k5Squirrel &#064; Feb 11 2006, 02&#58;21 PM) [snapback]44222[/snapback]</div>
    If you use the keys to lower the front don&#39;t you reduce the amount of suspension travel available? The nice thing about the keys is they are cheap&#33;
    I just had another thought about lowering that VHO. Is it a one or two piece drive shaft? You may need to relocate the carier bearing if it&#39;s a 2 piece.
    Has anyone actually done one of these?
    Jethro3.....SCIV? You guys are the VHO guru&#39;s.
    Dec 2005
    Dallas, TX
    Using his topic (sorry waveman) but if you lower it by the t-bars how low can you go before it starts messing with the alignment? all i wanna do is go 1 in.
    2001 GMC Sierra C3 with the 6.0&#33; Vararam King Cobra, TB bypass, No cats with two 3 inch cut outs and thats it for the motor. FOR NOW ATLEAST&#33;&#33;
    9.5 in the 8 mile
    6000K xrtalight h.i.d kit
    Jun 2005
    Round Rock
    I turned the bolt for the bars and installed the 2" drop shackles. Now I have the "SHIMMY" from the driveline angle issue and HAD to do an alignment even from just dropping the front 1". The caster and toe where WAY out.
    When the &#036; come in I will be doing a new spindle and drop hanger.
    On the Z60 suspension spindles there are basicly 2 choices. One will cause your steering to change and one won&#39;t. One will require a little grinding and bending, the other is a simple install.
    For the rear the only way to go is drop hangers and that will require a empty tank and an air chisel/grinder. The kit should include all shims to "Git &#39;Er Done".
    When you talk to the salesman MAKE SURE they understand it is the 2wd SS with torsion bars as 90% + of them have never heard of a 2wd with torsion bars. You&#39;ve already seen that.
    Be glad you don&#39;t have a 2005, it has larger front brakes and creates a whole different problem.......
    I hope this helps all of you, shoot me later if I am wrong.
    08 HHR SS
    Apr 2005
    Go with McGaughy&#39;s. I am. Heed Jethro&#39;s warnings though.
    Gone, but not forgotten!
    Oct 2005
    Houston, Tx
    Try joegibbsperformance.com. I just ordered 2 inch shackles from there. Their trucks may have some similar parts that you have.
    Feb 2006
    Cibolo,TX
    SCIV, waveman, and Jethro? I would like to see some pics of ya&#39;lls VHO&#39;s when your done.
