			Looking to do a Cam Sawp. LQ9 cam into LM7-  NEED HELP
					I have a 2000 LM7 in a silverado... (Really rare right? lol)
 I've found an 03 LQ9 and i know its a good choice cam for me, what i don't understand is if i need to worry about the following... Is this just the "bore" itself, and the cams are all the same size with different bearings, or are the cams ground differently?
 Is there a way i can tell before pulling the cam from this 03 LQ9?
 LM7 Specs:
 Cam Housing Bore Dia.	Bore 1/5 = 2.326, Bore 2/4 = 2.317, Bore 3 = 2.307
 LQ9 02-03:
 LQ9 03-07:
 Bore 1/5 = 2.346, Bore 2/4 = 2.326, Bore 3 = 2.307
 Thanks
 James
- You may not post replies
- You may not edit your posts
