Results 1 to 1 of 1
Thread: Looking for input on my parts list
    Jun 2015
    Hello guys! First post here, this is what I've got for a current parts list for my 5.3 swap. It's going into my '95 and will be using an '89 NV3500 (5LM60) behind it. Looking for input on this before I order parts. If there is any cheaper way of doing things I'd love to know too, especially the fuel lines! This is a very budget minded swap. Also I'm curious about the accessories. Can I use the stock 5.3 accessories with my truck? I do know I'll have to switch out the A/C compressor with my TBI one correct?
    $350 for Engine/wiring harness/ECU from my sisters '99 Silveraydo
    SWAP PARTS:
    $5.97 - NAL-12559760 Nipple fitting
    $104.99 Dirty Dingo engine mounts
    $71.72 AC Delco EP381 fuel pump or VPN-GCA758-2 Walbro 255 ($131.97)
    $4.97 (x4) - SUM-220690B Hose Ends
    $17.97 - RUS-644110 fitting
    $16.69 - RUS-644120 fitting
    $6.97 - EAR-9894DBHERL -6 AN to 14x1.5mm hardline adapter
    $10.97 - FRA-491971 -6 AN to 16mm x 1.5 hardline adapter
    $26.97 - SUM-230606 -6AN braided hose
    $64.95 - N1086 Centerforce Throwout Bearing
    $68.58 - Sachs NFW1050 flywheel
    $.97 (x6) - GM Performance #12561465 Pressure plate bolts
    $12.97 - Chevrolet Performance #12557583 Roller Pilot Bearing (For '99 4.8L)
    $784.45
    This is the truck it's going in:
