Results 1 to 10 of 15
Thread: Where should I begin with my 4.8??
    Feb 2014
    livermore, CA
    First off, thanks for having such a badass site. I have a bone stock 2005 2WD Tahoe, which is desperately in need of some modifications. What would you guys recommend to start off with (intake, headers, tuner, etc.). Also, what brands have you guys found to be the best. With a million out there, I want to buy the best the first time.
    Looking to get some new life out of the engine, and then plan on lowering it next.
    Dec 2004
    San Antonio, TX Area
    Step 1: http://www.nelsonperformance.com/
    What best brand are you talking about?
    Where are you located?
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Feb 2014
    livermore, CA
    I am located in Livermore CA. With all the different brands (K&N, Air Raid, Volant, etc), what have you all found works best. I know I can buy some cheap stuff online, but will $50 intakes be a waste of time? My tahoe is a dog off the line, and I would like to help it out a bit before I start to think extreme.
    Apr 2013
    Houston
    For the money your going to spend on the 4.8 you could easily buy a 6.0 and be way ahead.
    Arizona/Utah
    Quote Originally Posted by Slow04xcab View Post
    Agreed a 6.0 swap is your best bet in California. You will spend right around 2k, but you will net 80rwhp. Here is some quick math.
    Headers $500
    High flow cats $500
    Catback $400
    Tune $300
    Intake $250 you will need a Cali legal intake the $50 ones aren't legal.
    All that will net maybe 45rwhp.
    Basically you will spend 2k in a hurry for Cali legal mods and get way less power.
    Mar 2013
    Long Beach California
    Headers $500
    High flow cats $500
    Catback $400
    Tune $300
    headers and HF cats in cali??? HA! i wish!! LT's anyway.... i think they make shorties that are legal but from what ive read, GM did a pretty good job on the design of the stockers that the cost vs gain really isnt worth it. unless you have the spare cash, NEED the extra power and/or want the chrome... not saying i wouldnt if i had the cash though...
    i passed my swap with a spectre intake that is legal and is only 150 bucks (reason i chose it).. as for it vs kn&n or others... who the hell knows but are you really gonna notice 5 horses? Just sayin. good luck!!
    BTW, i have a 6.0 if you have anything more than a reg cab, just go with the motor swap. its basicallly a direct bolt/plug in for you. plus the thing looks basically identical on the outside... smog tech might not even notice it!!!
    CALI LEGAL ENGINE SWAP!
    Feb 2014
    livermore, CA
    Man, you guys sure know how to rain on a parade, but you make a lot of sense. My tahoe has very low miles, so maybe when the engine dies I jump on that 6.0 swap.
    Mar 2013
    Quote Originally Posted by RU11550 View Post
    hey hey now. isnt it always nice and clear after a storm???
    anyway, you didnt say if this was a daily. if its not registered for street, then forget what i said. you can get whatever you want!
    but if yoyour gonna do a legal swap, heres a tip... the ref uses the vin in the pcm to base everything off of. so if you want a 6.0, find an lq4 if you dont mind the lower compresion as they are way cheaper than the lq9. then just get the pcm vin changed to a legit lq9 equipped vehicle (0bviously one that isnt being used in the dmv system) and you should be good to go as the motors are essentially identicle..
    Sep 2011
    Best bang for your buck in California would be a tune, gears, and stall.
    99 rcsb silverado...... boosted.
    Arizona/Utah
    CARB approved LTs and cats do exist. Right around $1000 for a bolt on setup.
