fuel pump help please
I have a lq4 in a 68 truck. I'm running a 2002 camaro plastic tank. I have a 2002 silverado pump and module in the tank. I am running a return system with regulator on the fuel rail. I just installed a cam and started having lean issues. Installed a fuel press gauge and found the pump is not keeping up. Drops to 45 with throttle. So I want to install a walbro. I was going to get one from racetronix but I don't know which kit to get. Can some one point me the right direction or give me pt # for a reliable kit that will work. Thanks rob
- You may not post replies
- You may not edit your posts
