Results 1 to 8 of 8
Thread: 88-95 obs return less fuel system parts (i need help)
    Jan 2014
    What all is needed for 4.8/5.3 return style fuel system in a 88-95 obs Chevy I don't mind if its a little extra work, but I'm having to pinch pennies here, as I only have 80-90% of the funds as it is depending on the price I can find my motor at. any and all help is appreciated. Thank you guys.
    Edit: made some typos, want to run return style system and not the vett filter.
    Jan 2014
    The TBI motor already has a return line, so would these two fittings all I need besides a pump
    Rus-644110 and rus-644120
    Mar 2013
    Long Beach California
    this question has been answered numerous times on this site. in fact, its in the 2nd post in the STICKY.... i suggest you read through it. it answers both of your questions and many more you will have.
    http://www.ls1truck.com/forums/showt...4782#post74782
    http://www.ls1truck.com/forums/showt...046#post520046
    CALI LEGAL ENGINE SWAP!
    Jan 2014
    I'm sorry, I meant use the return line. Not return less. I don't want to go with the vett filter.
    It seems a cheaper rout to only buy two fittings and use the stock filter and lines.
    Editing first post.
    Jan 2014
    Think I found what is was looking for. And for any one els have the same question, here's a link
    http://www.fullsizechevy.com/forum/g...-obs-95-a.html
    Jan 2012
    warwick ny
    If you don't use the corvette filter you will need a regulator to get the proper psi.
    May 2010
    Galveston, Tx
    Pulled this img from the second link
    I'm the guy who made the diagram, don't know why the hell the guy though it was 98 only
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
    Jan 2014
    I was under the impression that the corvett filter held a regulated pressure of 58, and the stock fuel rails regulat that down to a lower 5x psi.
