Results 1 to 10 of 26
Thread: 4l80 swap what yoke?
    Aug 2013
    Clarksville, tn
    I got a 4l80 out of a 98 pickup that im puttin behind my 5.3. I just want to know what th400 yoke i need. Ive looked on the threads and searched google just no clear answer really. Here's a picture.....
    Gotta measure the depth and see how far a yoke will slide onto the shaft. Short or long th400 yoke.
    Thinking that one might need the short yoke.
    I'm sure some trans guy will chime in.
    1350 if I remember right is the 80e yoke part number I used its the long one.
    Aug 2013
    Clarksville, tn
    The yoke that came on in it is pretty short. I just heard people talkin about the splines and them bein shorter on some, and some have o-ring like mine or a clip. All I need is this yoke and I have everything for trans swap. Just tryin to get this goin asap.
    Sep 2011
    1350 is the joint size, the spicer part # for the long yolk that uses a 1350 joint is 3-3-5551x. The long yolk that utilizes a 3r joint ( most common joint on chevy pick ups) neapco part # n3r-3-9161x. The short yolk with a 3r joint is neapco part # n3r-3-9763x. Hope this helps
    Aug 2013
    Clarksville, tn
    I dont have away of cutting a the yoke if I was to get a longer one.
    Sep 2011
    I gave you the part # for the short yolk too.
    Aug 2013
    Clarksville, tn
    Yea but when I search for the short one with that part number no results found
    Sep 2011
    Where are you located? I've got 3 on the shelf in laurel ms.
    Aug 2013
    Clarksville, tn
    clarksville tn
