would i be able to run this cam with a stock bottom end ?
Top end is so far 706 heads Ls6 springs Ls7 Lifters
it says 10.5:1 CR i believe the 03 Lm7s have 9.5:1 would i be able too regardless or what can i do to bump it up.
Basic Operating RPM Range: 2,500-6,300
Intake Duration at 050 inch Lift: 220
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 220 int./224 exh.
Advertised Intake Duration: 278
Advertised Exhaust Duration: 282
Advertised Duration: 278 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.575 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.575 in.
Valve Lift with Factory Rocker Arm Ratio: 0.575 int./0.575 exh.
Lobe Separation (degrees): 112
any info would be great thanks
