Results 1 to 8 of 8
Thread: advice needed
    Jan 2012
    advice needed
    I've hot an lq4/4l80e. 222/226 597/598 113 with a stock verter. Its a dog down low till about 3k. I have aset of 243s i want to put on. Should I put the 243s on and see how I like it or replace can with something smaller and do the heads then. It also has a little surge in it especially in reverse. NP tuned also
    Aug 2012
    Mount Pleasant, Tx
    Get a converter and your problem is solved! This will also help with the surge.
    2000 GMC Sierra 1500 RCSB 2wd - 454 LSX powered drag truck...
    Arizona/Utah
    You need a smallish stall. Maybe 2800ish. That is a great cam for your setup. Those heads will help only a little bit, but a stall will make a night and day difference. Get in contact with circle d. They can get you taken care of and they have a low cost stall for the 80e now. You might need some fine tuning adjustments if your having surge issues unless its a big problem.
    Dec 2009
    DIrty south AZ
    x2 on the stall i ran my cam for about 3 months without a stall and it ran good but the stall made it seem like it has way more that the cam did by its self.
    Built 2 Run! 6XX HP/ 6XX TQ
    Jan 2012
    Thanks for the advice guys. I think I'll go ahead and do stall first
    Dec 2009
    DIrty south AZ
    make sure you get a trans cooler too if you dont already have one. as for the stall u wont be disappointed. its a night and day difference
    Jan 2012
    10-4 I've already got that big ol 40k sitting up front
    Dec 2009
    DIrty south AZ
    sounds good dude, if ya got any questions u can hit me up. im not a prob but i can prob help ya with your project.
