Ive got a 1997 C1500 truck with a 5.3 from an 02 silverado. Im running the stock steering gear box in the truck and the stock power steering pump on the 5.3. at low rpm I loose power steering. I thought maybe it had something to do with the 5.3 pump not pumping enough for the gear box at low rpm so I put a pulley from a 3.4 car on it and still no change. Could it be a bad power steering pump? Its full on fluid, and i dont think there is any air in the system and no foaming in the resevoir. Any help would be awesome, thanks!
