Ok so after amost a year i got it running and almost ready to try and drive.
My few final q's are concerning the tcc switch, there is a six wire plug coming from the brake switch under dash, an orange is constant and a white is 0v/12v brake pressed which is opposite of what i need. the others are all dead. what should i run to pcm?
The other is what does this green wire(B) of the drivers side trans go to? in the pic i have all the others listed and connected except the green. My brake and reverse lights work, my prndl on dash does not. that is what im needing to figure out.
hope this makes sence, thanks.
