My truck has been running like crap lately. Under load it coughs and backfires. When this happens the vacuum gauge will jump up 1-2psi. The plugs look fine, besides number 7 which is dark and sooty. I did a compression test on #7 and a few others and it checked out fine. It also sounds like I have a second wastegate on the driver's side(that might just be in my head though).
Changed fuel filter, plugs, swapped coil packs around, checked fuel pressure.
I'm going to drop my crossover and take a look at the flex pipe. Will also move #7 injector and see if the dirty plug follows. I was just wondering if anyone else came across a similar problem.
