Thread: intercooler kit
    Jan 2013
    Alabama
    intercooler kit
    I'm wondering what size intercooler kit I should go with for a 76mm turbo that's going on a ls3. Prolly gonna push around 600 to the wheels hopefully so any suggestions would be greatly appreciated.
    Arizona/Utah
    I would guess a 3" core should be sufficient, however, you will want to get the biggest you can fit/afford as it will be key to keeping iats undercontrol and making sure its not a restriction. 18x11" core seems to be a popular size and is the size included in many popular kits. If you can fit a 24x12" that would be a great size.
    Mar 2013
    Edmonton, AB, Canada
    I recommend this: CXRacing 31x12x3 Intercooler Kit ECLIPSE MUSTANG SUPRA off ebay. I DID NOT KEEP A/C. Its cheap and it works. Came with plenty of clamps, hose couplers and tubing. Although i needed a 90deg 3" to 4" for the manifold and a 4" to 4" for the turbo to air filter. It cost roughly $360 for me but thats cuz i live in Canada. Also check out my vid of the first start up haha: http://www.youtube.com/watch?v=Kp_ezcIKQdM
    Back Alley Motorsports 98 GMC
    -5.3l LM7 bored to 5.7l Thompson Motorsports -72mm T4 Magnum Turbo
    -TU1 Custom Grind cam(spec speed.inc) -799 heads
    -.660" Trick Flow dual valve springs -Forged Probe Pistons 3.902" flat top
    Oct 2005
    great looking turbo set up
    '92 Fullsize, swb rc
    5.3L/T56 conversion, comp XR275 HR cam .566/.568 lift 222/224 duration 112 lsa, crane dual springs, trick flow push rods, K&N Filter, Nelson Performance tune, Keisler shifter relocation kit, Boyd Coddington Smoothie II 18x8 235/55 up front, 18x10 295/45 out back, 2/4 drop, eaton lsd w/4.56 gears
