Results 1 to 10 of 16
Thread: Disk to drum brake swap..
    Ponca City
    Question Disk to drum brake swap..
    I'm needing a wider slick. There isn't really a good selection in a 16in wheels. With drums I can run a 15in wheel and there are tons of options in wheels and slicks.... My question is are the rearends the same and just the bolt on disk or drum section is diff? So I could keep my rearend and pick up the drums and stuff and stick it on. Or will whole rearend need changed
    Slowest in Oklahoma...
    Oct 2007
    Bandera, TX
    05-07 classic have factory drums that fit 15". I had a complete rear from my black truck, but not sure where it went. Lol, but I will have another shortly when I put my 9" under my prerunner build. I think the brakes will swap right over, just backing plates, shoes, and drums. But it would prolly be easier to swap entire rear out if u could find a good deal
    single digit street truck
    for build info
    Pm'd you
    Pittsburgh, PA
    FYI my 14bolt came stock with drums. i took the brakes from the 10bolt and swapped them over. nothing else changed, so disk to drum might be similar
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Sep 2011
    I've got a 97 obs rear end with drum brakes and I'm needing to run a 15 " rim. Any of you guys think I could possibly convert the drum brakes to work on my 00 model rear end?
    hmm I would just try putting stuff together and see what you come up with. May have to make some brackets and what not
    Oct 2011
    I need to do this as well...
    Sep 2011
    Yeah I've got a 00 rear diff sitting right beside it, might as well start pulling parts off and seeing what's up .
    Ponca City
    Pretty much finished it tonight. Gotta bleed te brakes tomorrow. Was actually very straightforward. Thanks camaross for some pointers.
    no problem. Glad you got it done!
