New to the forum and LS engines. I have tried to read up but there is just so much that only makes sense after you know it, so please go easy on me if I'm asking questions that should seem obvious.
I'm helping my buddy with a rock crawler build, basically all custom frame and suspension with an old school Jeep body and grill, and after reading up we decided that LSX powertrain was the way to go. Wanting to stay in a budget for engine he jumped at the opportunity when he was able to get a '99 LM7 drop for $280 (no harness or computer). We will be buying a used factory harness and PCM and doing the wiring mods ourself, getting the PCM reprogrammed.
The question is this: Without spending a lot of cash, what are worthwhile upgrades to this engine? We'd consider dropping in a factory cam from a LS? motor, but don't know it's be worth the $50-$100 in parts. What would be the best (stock) cam that would be a direct bolt-in (springs and pushrods matched, of course)? Also, what throttle body would serve best? Would an injector upgrade be in order? While the engine is apart for inspection, would we benefit from swapping in 4.8 (flat) pistons? Is there anything to gain by "gasket matching" heads?
Basically I'm looking for the "formula" to get more out of this on the cheap, with a focus on torque as much as HP. Though HP is good for a large hill climb, it's the torque that pushes you over the rocks.
For now, we'd considered the following:
air intake (before TB) will just be a short large diameter tube and a K&N filter... no restrictions before TB.
The plan for the exhaust is to cut just behind FWD O2 sensors on stock exhaust and run same diameter, unrestricted, from there back.
All smog will be deleted.
Fan will be electric.
AC compressor will be retained, but not engaged (except as occasional air compressor for tires, etc).
Manual (SM465) trans
F-body oil pan (for rock clearance)
With this setup, based on what I've read, we expect to see around 315-ish HP. Is that about right? Is there a cam combo that, along with Camaro TB and performance PCM tune, will get us up to 400+ HP without sacrificing low end torque?
Also, does anyone here do/recommend performance tunes? We're considering garretttuning.com as the price seems good and it seems like it'd include whatever we need. Is there a better solution recommended?
Thanks for any advice and assistance.
