Results 1 to 10 of 13
Thread: Milled 243's and ptv?
    Dec 2011
    I have a 2000 rcsb with a stock 5.3. I have a set of 243's on the way that I plan on milling .030 and I am in the process of cam shopping, was wondering what off the shelf cams are safe. I know measuring is the only sure way to know but I thought I might be able to get some ideas since this is a popular head swap. I was thinking something along the lines of a tr224 or the like. Any suggestions would be greatly appreciated.
    Apr 2006
    Bellevue, Nebraska
    I'm running flat top pistons in a 5.3 that I bored to 5.7. Milled 241's .03 and I'm using a .041 gasket. I'm running a tsp228 cam with a .588 lift. No PTV issues.
    5.3, 243's milled .030, 222/226 .598 cam
    Works fine for me
    2002 5.3, 799's milled .030 Stock Gm gaskets, TR220/220 .551/.551
    97 xcab c1500 lm7 5.3 swap 343RWHP 329RWTQ 13.40 @ 101.97 2.03 60ft. MODS: Longtubes, 3200 stall, TR220 112lsa, .030 799 heads, NNBS intake, PTM 92mm TB. 4" PVC "hot" air intake 3" single exhaust w/cutout 3.42:1 gears, 29" tall tires. Dyno tuned by flaco
    Dec 2011
    Thanks for the input, I've settled on the tsp 224R. My other question is about pushrod length with this setup. I'm going to order the length checker with the cam kit and a couple sets of pushrods to make sure I have the correct ones on hand, what possible lengths could I need?
    That cam uses stock length pushrods with unmilled heads. (7.400) So, math it out. You plan on milling heads .030, that'd give you a good starting point of 7.370 for pushrod length.
    Apr 2006
    Bellevue, Nebraska
    Order 7.35 and 7.375. it "should" be one of the two. I used 7.35 on mine and it works.
    pushrod length checker does wonders
    Simple: 408 on steroids!
    single digits coming soon!
    Dec 2011
    I had read that ls7 lifters affect pushrod length also - anyone know for sure?
    Milled .040 799's here, LS9 gasket, 218/218 60X lift, no problems.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
