I did this a while ago just forgot to post up. Its and easy upgrade but thought it might be useful for some. Here is the part # and link for the ARP trunion upgrade. 13702-KIT http://sdparts.com/details/competition-cams/cc13702-kit
Not everyone has access to a press to do this job but any one can get a $20 vise. I could have used a press but this seemed easier.
Tools needed
Hammer, Brass punch, 3/4" socket, vice.
Set your socket up in the vice like so
There is a flat side to the rocker that is easier to set flat onto the socket. Place this side down.
It will take a couple good whacks with the hammer and the punch to get the bearings to push out.
Here is your rocker without the bearings
Now take the one of the new bearings and place it in the rocker and press it in with the vise. You dont have to get crazy just till it bottoms out.
Now slide your new trunion in and place the outside then other bearing into the rocker.
Line up the installation washers and place the whole unit into the vice
Install your new snap rings and you are finished. Now just do it 15 more times.
It pretty much follows the ARP instructions but just thought I would toss it out there.
