Thread: Help with connector identification
    Nov 2010
    Coldspring, TX.
    Ok, I'm hooking up all my wiring connectors to my fuse box on my conversion and I have two connectors that I cannot seem to locate where they connect to... don't seem to have a mate connector. Can someone help out an old man?
    Truck info. Harness is from a '02 v8 truck, my truck is a '99 and was a v6.
    First connector: on the '02 harness located near the fuse box. Has three wires - brown, black w/white stripe and a gray w/black stripe. Looks like it snaps into a hole, possibly on the fuse box case. First pic is one I found on the web, I've circled the connector I'm referring to in RED.
    Second connector: on my truck's body harness coming out the cab and is also located at the fuse box. I took pictures as I disassembled and I see this connector on those photos, but unfortunately I took the picture after I unplugged the connector.
    Current project.
    1957 Belair
    SOLD!
    http://www.ls1truck.com/forums/my-ga...rkwhite61.html
    1999 Silverado RCSB
    2004 LS6
    4/6 drop
    frame off rebuild
    Nov 2010
    Coldspring, TX.
    After doing more research, I'm "guessing" the first connector (three wired one) is the C153 connector used for 4wd which I can ignore. Thoughts?
    Still no idea on the second connector though.
    Current project.
    1957 Belair
    SOLD!
    1999 Silverado RCSB
    2004 LS6
    4/6 drop
    frame off rebuild
    Nov 2010
    Coldspring, TX.
    Nobody?
    Current project.
    1957 Belair
    SOLD!
    1999 Silverado RCSB
    2004 LS6
    4/6 drop
    frame off rebuild
    I don't have the same truck as you by any means, BUT that first one I was thinking either 4x4 switch or torque management plug which would hook to body harness. The second plug looks like a fuel pump prime test port, I have one on my firebird that looks just like that except mine is grey.
    FREE BUMP!!!
