ignition feed problems
i had two wires that i had to transfer to my new 2002 pcm from my old 97 pcm
specifically these two
02 blue connector:
#19 repin with 97 black conn. #18 PINK Ignition Feed
#75 repin with 97 blue #4 PINK Ignition Feed
looking at the gm service site it says that the first will cause a no crank and the second will cause no change.
well when i was removing my old harness i fucked up and cut them and i dont know where they go now.
sooo can i hook them to a hot in run source and fix my problem?
pin color circuit number function symptom from faulty circuit
4 PNK 539 Ignition Feed No Change
18 PNK 439 Ignition Feed No Start
- You may not post replies
- You may not edit your posts
