modifying my harness, need some help please
whats up, i started modifying my 03 silverado harness for my c10. There are two wires that i dont know if i need. they are from the c2 fuse box.
the 1st one is pin f11 DK GRN Park/Neutral Start Switch Signal
the other one is d3 D3 LT GRN Park Neutral Position Switch Park Signal. i dont see the on my wiring diagram. do i need to keep them in the harness and fuse them, or can i take them out? thanks
You can remove them. Be sure your tune is set with the PRNDL switch equipped to reflect no.
- You may not post replies
- You may not edit your posts
