Results 1 to 8 of 8
Thread: Best flexplate for 4L80 swap?
    The Garage
    What is the best 4L80 flex plate when upgrading from a 4L60 to a 4L80? I'll be using an LQ4 block and would like a STRONG flexplate. Thanks in advance.
    Pittsburgh, PA
    research pointed me to the TCI sfi one
    circle D sells one thats pretty badass for more money
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Jan 2012
    Baytown, Tx
    Which tc are you going to be using? I just bought the 278mm tc and they told me to use my 60e flexplate as the 278mm tc is based off of the 3 bolt 60e tc.
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
    1967 Chevy II 5.3 w/ 76mm snail
    get on tci's site, there is a specific one for the 60e and 80e. I recommend tci, never had an issue with it. Really ensures you're a little safer if your truck is gonna make power.
    The Garage
    Got it, and what about this spacer I keep hearing about? From what I have researched, there is some mention of needing a spacer between the crank and flexplate in order to properly mesh with the starter's teeth. Also, Alan, people tell me you make a conversion wiring harness for swapping from a 4L60 to 4L80. Is that right?
    The Garage
    I'm leaning toward this one:
    http://www.summitracing.com/parts/tci-399754
    Pittsburgh, PA
    thats one i got i do believe
    412 Motorsports
    The Garage
    I'm still a bit confused about this 'internal vs. external balance' thing. What is that all about? Also, do I need a 168 tooth flexplate? I'm more trying to get a flexplate I can just bolt in and go with.
