Results 1 to 10 of 14
Thread: 2000-06 silverado parts
    2000-06 silverado parts(reduced)
    I have a few parts off my truck and a new engine. All prices are OBO
    1) 160amp altenator still with tags from LKQ off a 2006 with 30k miles - $60
    2) A/C compressor off an 06 with 23k miles - $70
    3) Heat and air dash unit from a 2000 - $40
    4) Cruise control module off a 2000 - $30
    5) Driver and passenger airbag off a 2000 - $60
    6) Airbag sensor from a 2000 - $20
    7) NV 3500 5 speed cross member and shifter - $30
    8) stock radio from a 2000 - $25
    9) Aluminum truck bed toolbox - $70
    10) Adjustable slave cylinder new in package- $35
    11) Complete Lt1 stock rearend, no idea what gears, nice and rusted but probably good internals $30
    I have a lot of under hood and under dash brackets also, truck was gutted for weight reduction, so if there's something you need for a silverado just ask and I might have it. PM for any pictures I don't have listed. I'm in ft worth or I could ship some of the parts if need be.
    Mar 2010
    Paris, TX
    What are the dimensions on the toolbox. I have a step side so it needs to be narrow.
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
    Feb 2011
    Barnwell, SC
    Do you have the a/c controls?
    Toolbox is for a fleetside sorry, I'll get exact dimensions friday. I do believe I still have the controls, I'll have to look through my parts
    and I'll get back to you, thanks
    What engine did the ac/ compressor comme off of? 4.3/4.8/5.3/ or 6.0??
    6.0, but I don't think it matters between the 4.8 5.3 and 6, correct me if im wrong
    Dec 2011
    Texarkana, Texas
    I'd be interested in that A/C / Heat control unit if the backlighting works and is the same as 2006
    06 Silverado 4.8 - Lt's, Y pipe, and Flows dumped at cab
    I don't remember if the lighting worked or not, is that a common problem, something other than the bulbs I mean? I have no idea if it's the same as 06. Let me know if it will work, thanks
    Jan 2012
    DFW, TEXAS
    a/c compressor still available?
    Feb 2011
    Pittsburgh, PA
    What's a stock 04 alternator run, 105 amps?
