Results 1 to 10 of 35
Thread: Project EFI to Carb in my 2007 Silverado
    Sep 2006
    THE 405
    Well, I've decided to do something a little bit different from the normal this next year on my truck. Most people will say "what a dumb idea" blah blah blah, but I'm going to take a bit of an old school approach at going fast next year.
    The parts list I have worked up so far is:
    Quickfuel 950cfm e85 Carb
    MSD 6LS Ignition
    20gallon Aluminum Fuel cell
    Holley Billet 150 fuel pump w/12-803 regulator
    Push lock fuel line
    Still trying to figure out which throttle pedal to use and which/how long of throttle cable I need to buy. Thinking prolly just a 99-02 silverado pedal and some kind of Lokar cable. Any suggestions are appreciated. Thanks
    2007 RCSB|DTR81 built LSx 3xx|PRC|NX|BOGART|MSD|QUICKFUEL 950 E85|4L80|FTI Converters|Smith RaceCraft|Racepak
    midweststreetcars.com
    Sep 2006
    THE 405
    First little bit of this project showed up today!
    Jan 2010
    Moore oklahoma
    Right on Danny, I think it will be pretty sick my self man. I mean who can fault you for doing something different.
    2001 Silverado, work in progress. Add a vette servo and Nissan e-fans
    Feb 2011
    Barnwell, SC
    That's like selling your flat screen and buying a old floor model..... Jk. It's definitely different and should be interesting too. Good luck with the build. And the first thing I thought of when I saw your carb was a leprechaun.
    Birmingham, AL
    im excited to see the results....
    01 Silverado
    Nice project, you might want to go with a bigger cell.. You will wish you had those 5 or 6 extra gallons.
    Going to be badass
    racetruck
    Sep 2006
    THE 405
    Just thought of a possible obstacle. Since I'll be doing away with factory PCM, how will I start my truck? I had to hook my park neutral switch up before it would run when I put the new trans in
    Basically I don't know if the pcm tells the bcm anything that will cause troubles once the pcm is gone. Thanks
    Pittsburgh, PA
    Could always resort back to non-databus wiring aka 99-02
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
